Ok, I drove my truck home a few months ago and half way home the drivers side rear hub was locked up, so on the side of the highway my brother and I pulled the tires off and eventually decided to just bleed the brake to see if that would fix it... The brake released and off we went. After we got home we ordered the parts for a complete brake rebuild minus the air pack.
Last week I went through the system, flushed the lines with alcohol, rebuilt every cylinder as well as the master cylider(which was amazingly clean) put new Dot 5 in the truck etc... I drove it around the block and when I got home the same rear drivers side hub was hot, non of the rest are even close to its temp. The pads are backed off of the drum all of the way and it still gets hot. The return spring is on there as well.
Does anyone have an idea? I am supposed to take it on a trip on friday...
Thanks
Thanks
