gunboy1656
- 23
- 38
- Beaver Falls, PA
Going to try. My dad and I are starting on a new project, well it is arriving today. A mule with a 106mm recoilless rifle. So I have to take him to a vehicle show.
how big are the stars suppose to be?Only thing I see your stars need to be bigger.
Is this a rule am not familar with???!!! lolBut.... family is still more important than the truck.
Man, I feel for you. I hate that sinking feeling when I am getting close to finishing a job, and start thinking to myself how smooth it went, only to realize I left a part off that goes on under everything else, and basically need to go back to square one, do not pass go, do not collect $200. If you need a tissue, I believe I have some around here somewhere.Started it up today..... Radiator still leaks and horn stayed on. It wasn't an electrical problem. Took the horn apart. Found the piston in the horn was corroded and stuck open. Cleaned the piston and tube. At least I got the guts back in the doors and the cab top on. Anyone need a driver's door regulator and door catch? PM me. I am pissed. I am so close to being done and now I have to pull the radiator again.![]()
