Csm Davis
- 382
- 83
- Hattiesburg, Mississippi
Read post 34Which transmission's top gear is the tallest? The overdrive Spicer or the Allison?
Lower the gear on the transfer case the faster the input shat moves which will be you output n 205 coughSorry, been away for a bit. M931a2, not so much for more speed, but for a slightly lower rpm while cruising on flat ground. How would a transfer case increase top speed, I thought they where 1:1 in hi gear. Ive got 14.00x20 tires.
What.... ?Lower the gear on the transfer case the faster the input shat moves which will be you output n 205 cough
This ^Easiest way is to install 16.00 tires and turn up the injection pump. Add an EGT gauge to not melt the engine down.
This is my plan for my M923. Ditching the 11.00's and going to 16.00's for better highway cruise (lower engine rpm's and softer ride).Easiest way is to install 16.00 tires
That will be the last time that guy shoots a bird at a tank operator !!!!.
How about Road Kill Prius? With a tank...
Prius Smash - Roadkill | MotorTrend
Once the Prius testing was all said and done, naturally there was only one thing left for the Roadkill guys to do- crush the Prius with a tank!watch.motortrend.com
No additional top gear to unlock. 6cta doesn’t mind spinning a little faster but if you are running NHC 250 keep it under 2,200.Not sure what the previous owner did to my '91 M939 (guarantee they turned the fuel screw up) but it definitely scoots just fine, and cruises easily at 65mph. Its bobbed, and lightened up those brakes will throw you through the windshield if you don't respect them. My buddy is a big diesel mechanic, and he said the Allison in these has another top gear you can unlock.....but I have zero idea if that's true or just rumor as I have not researched it. All I know is that 65 is easy, it might have more but didn't want to spin it to 3k rpm. Not sure I'd really want to send this sucker down the road any faster anyways, especially with how people pull out in front of you these days. Wedged under my front differential isn't a great look for a Prius.
They can turn 2700 before the valve springs give out. 2400 rpms unloaded isn't a big dealNo additional top gear to unlock. 6cta doesn’t mind spinning a little faster but if you are running NHC 250 keep it under 2,200.
