srodocker
- 68
- 48
- Lacey, Washington
You oregon guys set something up im sure a few of us from up here will come down. including me. dunes are fun i'll bring the quad!
My apologies for the hijack to the original poster... Guess us Oregon peeps are social butterflies.... Of course you couldn't tell it by the member mapI thought this thread was to help a fellow SS member fix his truck...
My M35a2 was exactly like this before I turned up the fuel a turn. Once the fuel was turned up it always starts quickly and without any throttle needed.It runs really good up and down all rpm ranges. It starts in an instant (as long as you have a little throttle). In order for it to idle, I have to either pull out the hand throttle or screw in the idle adjut screw at the IP, around 3-4 turns.
I'd love to meet up with some Oregon guys!
Just out of curiousity, I saw what I believe was a nice 5 ton in inner SE Portland the other day...anyone on here?
It was parked only a few blocks from my business, and I've never seen it around before (maybe seeing my deuce driving by everyday "inspired" someone)
My Deuce is turning into a daily driver, the poor F150 hardly gets driven
I could do that. Some steep hills between Roseburg and there but would be fun going downhillThere is a rally first part of June near Grants Pass, SOMVCC 9Th annual I believe.
EUREKA!! I think I finally found the problem...I went ahead and pulled the IP yesterday, and when I took a closer look at it while it was sitting on the bench, I seen what is most likely the problem...Nasty, rusty water in the HH! I'm sure that can't be good. I already bought a new pump so I will put it all back together and see what the results are.
Intrestingly enough, there was water in just one hole (#1 injector).
