Jordankier
- 1
- 3
- Palmyra ny
so after hours of searching for an answer I’ve come up short. I have a bobbed m35a2 on 395/85r20 mrap wheels. I have my fuel turned up some but not all the way. I don’t use the truck for more than what you’d use a pickup truck for. I want to be able to drive the truck at 60 without the motor screaming to the moon. I know people keep saying the deuce isn’t meant for speed so leave it but I don’t plan on pushing it past 60 I just want to keep the rpm in a much more conservative range for long hauls since I’ve gained much more power getting rid of an axle and 6 tires. My question is what’s my best bet for overdrive? Read a few posts about an overdrive gear for the spicer 3053 trans but cannot find someone who actually makes it. There is also 4.90:1 gears from overuson for 1200 a set. Seems like those would be a little high for the 395s. I just had a brand new driveshaft made so I’d like to stay away from an external overdrive unit mounted aft the transfer case. Any suggestions would be great!
