Finnegan1008
- 161
- 43
- Connecticut
Based on the advice from another thread, I just went through the exercise of aligning all of my pulleys. Along with this, I replaced my wobbly crank pulley, replaced my harmonic balancer and put all new belts from hillbilly wizard.
This eliminated my best squeal for about a week.
Since then I’ve put about a hundred miles on the truck. At first, the truck was producing a slight squeal on a cold start if I gave it any throttle. This would clear up pretty quickly once the engine came to temperature. Now I noticed the squeal is becoming more persistent, and the Belts now starting to squeal momentarily from a dead stop.
My belt tension seems adequate, I’m resisting the urge to increase the tension and risk of abusing alternator bearings.
I’m wondering if maybe I have an accessory that’s starting to go bad? I have what I think is a slight bearing noise coming from one of my alternators. When I start up my GEN 2 light will stay on, and my electrical gauge will read below 24 V until I blip the throttle then the light will go out in the gauge will go back to 24 V. If I do this the GEN light will stay off.
I saw a YouTube video where a guy change the alternator pulleys out and supposedly eliminated his belt squeal, to me it sounds weird that the factory pulleys wouldn’t work with a fairly standard belt.
Does anyone have any ideas on how to fix this? Could one of my alternators be going bad causing too much resistance?
