Picture from FMTVA0 inside relay dash cover
SausageGuy
35
Kansas City MO
Anybody have a pic of the factory label from inside the dash panel of the relay layout in FMTVA0? The exploded view in the TM is confusing as to which relay is where. My truck seems to have had many relays pulled for another vehicle.
Ronmar
7,943
Port angeles wa
Depending on what truck you have, some of those relays may have never been there as those features were not used on the vehicle, like the trans cooler relay not used on the 1078-1079... They spec four separate relay part numbers, you really only need two. 5 post relays will plug into and work in all locations, so you only need those in 12 and 24V coil versions...
What truck do you have. I can take a pic this afternoon of what relays are actually used in mine if you want...
