Brian Thomas
- 1
- 0
- West Jordan Utah.
Have searched but cant find specs for the pionts gap on the OA331. Any one know this?
If your truck uses a Delco distributor I would strongly consider checking to see if you can swap it out for a GM HEI distributor. I used to swap those out in old GM products. The HEI is electronic with everything contained inside the distributor, just hook up one wire to +12v off your first battery (and a switch of course) and you are good to go! It is VERY reliable and they are fairly easy to find.I did some research and found the REO 6 cylinder uses a Delco distributer.
RL
