Thank you very much for finding that model number. Primary and secondary clutches, drive belt, alternator, and the fuse block label from under the seat if available. Maybe more later as I go along
drive clutch has two options depending on date of manufacture. You'll have to look at the label on the right forward frame rail and reference it to make sure you order the right parts, make sure you don't lose it.
1323443 ASM-DRIVE CLUTCH,DSL,M [INCL. 2-11][TO 9/17/2018]
1323692 ASM-DRIVE CLUTCH,DSL,N [INCL. 2-11][FROM 9/17/2018]
driven clutch, same as above. reference date of manufacture to ensure correct part
1323444 ASM-DRIVEN CLUTCH,DSL,M [INCL. 2-16][TO 9/17/2018]
1323711 ASM-DRIVEN CLUTCH,DSL,MI [INCL. 2-16][FROM 9/17/2018]
drive belt
3211225 Belt, Drive
alternator
3023106 ALTERNATOR
Forward fuse box label: 7183782 LABEL-FUSE BOX
Rear fuse box label: 7183783 LABEL-FUSE BOX
