epartsman
- 0
- 0
- Jacksonville/Florida
I tried new relays and the breaker to no avail. I loosened the line to one of the injectors and spun it over and I had no fuel coming out of the line. I used my test lead and put 12V to the terminal where the heavy gauge pink wire was connected and I did hear a sound, kinda funny like a choke spring unraveling but a sound non the less. I tried to spin it over with the test lead attached and still no start. Does that pink wire have 12V power with ignition on?
I still have some fuel pressure at the filter as it still streams fuel when the top bleeder is opened. Does the IP require a certian amount of pressure to function?
Maybe the fuel pump is weak. I know the diapragms didnt rupture as there is no raw diesel in the crank case and it still has to be functioning somewhat otherwise there would be no pressure at the filter.
If the T chain let go is there any way to see if the cam is turning without major surgery? I hope this turns out to be simple but I will have to wait for the hour I have tomorrow night to do some more diag. Any ideas are appreciated. Thanks!
