chapmjw
- 0
- 1
- Elba/Albabama
Hi,
I've had the 1990 M923A2 for about a year now and I think I have a battery issue that I would like to confirm. If I go a day or so without running the truck and then start it up, it will run like trash. It sounds likes a miss firing engine trying to die. If it has only been a day or so since last running it will usually only run like trash for a few seconds, then it will run perfectly. If it has been more than a few days it will only run trashy. I've never let it run like that for more than 10 seconds or so. To get it going again I have to charge the batteries and try again.
I have checked and cleaned all terminals under the seat.
I have checked for current draw when vehicle is off. (none found)
I have checked battery water level.
The batteries charge to 13Volts and show 12.9volts the next day.
The battery gauge before starting is just in the yellow on the dash gauge.
While running the battery gauge is right on the Gen when the battery switch is turned off.
Has anyone else experienced weak batteries doing the same thing?
What is not being powered correctly to cause it to run so poorly?
Any advice is greatly appreciated
Thanks
Jim
Thanks
Jim
