- 10,859
- 745
- 113
- Front Royal, VA
Made some progress on the -725.
First, the bad news - the tire shop is having problems removing the run-flat inserts on the 11.00x16 XLs that came off the Marine LAV. They can't remove them, so they will be giving back to me to remove. I now know how to, but it's a PITA. Then, I'll have to send back to have them mount the suckers. Blech. Back and forth, yadda yadda. SO - since my rig is now sitting on concrete blocks, and two of them fractured, I can't get anything done underneath the rig for the moment. That will change in a couple days.
Good news - hooked up all the vacuum lines, the engine is ready to start under it's own power now, I just need to pick up a set of batteries.
I also got some electrical issues fixed, since the previous owner Bubba-fied it with cut wires and bad splices. Found one reason the turn signals didn't work, they weren't hooked up right! Now they are.
Also got a lot of little parts blasted, wire brushed, primed and painted. The cab got a few parts installed, and I began prep for wire-brushing, priming and painting the inside of the cab tomorrow. YAY!
Yes, it is the last minute, I am taking a lot of Paid Time Off to get this rig done, and I will be trying like H E L L to get it done for Aberdeen!
Here's a few pics for you guys.
