OK, been tackling the coolant issue for about a week and a half. I replaced all the 2" coolant hoses and the 5/8" heater hoses over the past week or so. As stated in a previous thread, I thought I had some overheating issues. Turns out the water temp gauge wasn't grounded to the gauge panel
![Mad :x :x](https://www.steelsoldiers.com/images/smilies/icon_mad.gif)
. Oh well, at least this prompted me to flush the coolant system out, add a coolant filter, and put fresh coolant in the system. You can see the temp reading differences in the pics. You push it in, it's not grounded. You pull on the gauge so the gauge hold down bracket in the back mades contact with the panel, it's grounded.
I went through and repacked all the bearings and rebuild all the wheel cylinders. When I cracked open the first hub I noticed fresh red grease...whew, they repacked all the bearings....I thought my work was done, but my gut feeling said to keep going and look everything over. Boy am I glad I did. Every wheel cylinder were the original wheel cylinders that came with the truck...no joke. With only 1200 miles on the truck the insides looked great, however the boots were pretty bad as you can see by the pic. Also found that everyone of the 4 hubs had dragging brake pads. Must have been going on for sometime because the paint on the inside of the hubs were bubbled. Nothing was warped. I also got my WIX 24019 Coolant Filter housing in the mail today ($28 shipped each) and decided to get them on as well. It was pretty uneventful.
Tomorrow I am planning on installing the Air-O-Matic. Hopefully the install will be uneventful as well
Projects Completed:
Added WIX Coolant Filter 24019
Replaced all 5/8" heater hoses
Repacked all rear bearings
Replaced all rear inner seals
Rebuilt all rear wheel cylinders
Added tire inflation extensions to rear duals
Put anti-seize compound on lug threads
