- 143
- 17
- 18
- knoxville tn
Experts on Wrecker operation (M936A1)
Have been going over the TM's, and realized i don't know the difference between the spring brake override switch (the one on the far right of the pnl) and the PTO spring brake override switch (located on the right side and just under the steering wheel). I know and understand the spring brake override switch and what it does and check it when starting the truck etc.. but have never used or checked the PTO spring brake override switch. Not sure what is different about the PTO spring brake override switch and when i would use it instead of the "normal" spring brake override? if given the name, they both override the spring brakes. The TM (at least the sections i've found doesn't give any use or reason for the PTO switch, just a description). so what is different in there operation or affect? and when would i want to use the PTO one instead of the "normal" override? (i realize the PTO is push and hold and normal one stays overridden when pushed till pulled back out). and i have never tried either when the wrecker PTO is engaged.
thanks
thanks
