PTO's
Barrman
1,782
Giddings, Texas
Will a 3052 or 3052A transmission PTO bolt up and work on the M35's transfer case? I have two of everything except winches. Just one of those. I was thinking about a rear winch and started wondering what parts I would need to collect to make it work.
Thanks.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
No on working on the transfer case. I bought a dual output PTO for the dump on my deuce.
Rear output is the shaft to the right in picture.
Dennis
gringeltaube
Staff Member
2,526
Montevideo/Uruguay
TheBuggyman said:
Clark Truck added what they call an accessory drive (rear output) to my five ton's PTO, I think they told me that they could add it to my Deuce PTO also before I found one on Ebay.
Yes, only the rear output section is the same for deuce and 5ton and it can be added without removing PTO/tranny.
2.5 and 5ton PTOs are same size but not interchangeable.
Deuce tranny PTO (numbers are Mod# 303454 3 or ORD 7061137), front output only: WN-7-28, double output: WND-7-28. See manual TM 9-2520-246-34.
T-case PTO is P-136-C.
Barrman
1,782
Giddings, Texas
Does anyone remember how Tom, Spicergear, did his PTO's? He had a front winch on his Blue Duece and then he added the hydraulic crane in the middle. When I was at his place in March, he was mounting up a rear winch.
Thanks for the numbers on the PTO's guys.
DDoyle
80
West Tennessee
IIRC - there is some sort of interference between the alignment to the output of the deuce accessory drive and a crossmember. Check this before spending money.
Regards,
David Doyle
Barrman
1,782
Giddings, Texas
David, thanks for reminding us of things that will really hurt once the money is all spent. Big help.
Dennis, can another PTO be piggy backed onto the one you pictured? It has the 6 bolt cover and I just started thinking.
1,808
Thinking Tom used a transfer case PTO. I offered him a dual output deuce PTO and he didn't need it.
BFR
Rocket Surgeon
2,330
42
North Georgia
the tranny pto is pretty close to the driver's side frame rail (like 2" max)
...also the side of the tranny where the pto bolts on is vertical, the cover on the pto (when mounted) is close to 45 degrees "faces" up[/code]
country
393
Feasterville, Pennsylvania
Transmission PTO can accept an Accessory drive as mentioned above. it is a one directional PTO, typically used to run a pump of some sort, as the speed will be determined by the engine RPM
This accessory drive will also fit on the 5 ton PTO for the winch
Both point to the rear of the trucks
We have a few of the Transfer case PTO's. their speed is determined by selecting a transmission gear and putting the transfer case in neutral, then set the throttle, and you have 5 speed options. many times this PTO has a gear on it and runs a chain to a pump or other gear box
we also have a few Hydraulic winches, with pump, tank, valves, lines, that can be mounted anywhere you like on a truck
Dave
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
Not much space to work with. There is a crossmember to the rear of the pto. Wasn't in the way for my install, I had a slight downhill angle on the pto driveshaft.
I have no idea if you can piggy back transmission PTO's.
Here is a pic of the rear output install on my deuce.
Dennis
