pulling deuce?
HASSON1911
24
roseau/mn
This coming wed. I will be going home to pick up 2 more m35a2's. the only problem is with one there is no cab or anything to sit on. So I was wondering if there is a safe way to pull it about 15 miles with my working M35A2 (Isabell?)
eagle4g63
34
North/west Indiana
Anything is possible, EASY............depends on your skills and equipment and access to product.
The thing has to be able to withstand the force of a 15,000 pound truck jerking it around, others wise easy as pie............they were fabricated to begin with................but at what cost!!!
HASSON1911
24
roseau/mn
Okay thanks guys, I do think jdknech wins, ill call around to some of the farmers nearby with lowboys for combines, wouldn't even have to be for the day just 2 hours. But that tow bar will definitly be looked into for future recoveries.
Major Sam
Arvada Colo
just be sure your transfer case is in neutral, save your gears! Better yet, disconnect the rear drive line and tie it up. Had a friend tow his duece and hi t a bump at some time and it jumped into gear somehow. Major damage to engine (over revved at 55 mph) and trans. Good luck
WILDBOY6X6
Newark ca
HI yes have it towed, on a flatbed too,to flat tow 1 with a tow bar,you need to tie the wheels straight or when you turn they will go the other way,make you jack knife when you stop too. I used to tow them full time in cal guard FMS .
HASSON1911
24
roseau/mn
Well, all the steering components are there but there is literally nothing to sit on, this is why I think it would be safer and easier to just put it on a flat bed.
