Buffalo Dan
- 2
- 3
- Pe Ell, Wa
Chasing electrical issues . This cucv is new to me and just trying to get it running . My questions are :
1. The purple wire that I’m holding with the diode is that supposed to go the starter solenoid? Be cause thats
2. Where does the other purple wire go that’s tapped off ?
The wire I’m holding goes to the starter solenoid but only has 11 volts with key in start position . The one that’s ended has 24 volts with key in start position . I have 24volts at starter relay and it’s working and 24 at the 10 amp fuse . I have read and look at wiring diagrams but still not very good at it .
Thanks for any help
Thanks for any help
