Put on the Spin On Filters Today!
dabtl
Denton, Texas
Put the jatonka spin on oil filters today. They look good and the oil pressure seems to come up quicker. A neat installation.
Now, if only John would make spin on secondary fuel filter adapters, it would be a snap to change the filters. Hint! :)
dabtl
Denton, Texas
I will try to take some tomorrow. If you have not gotten them yet, do so. You are kind of new here, so they have been photo'd before. Just look great and for eight full hours have worked fine.
I will let you know how good they are in a couple of years. :lol:
OD_Coyote
58
North Bend, WA
dabtl - I bought a set of spin-on adapters from jatonka too, but I have not installed mine yet. Did paint the adapters before you installed them?
dabtl
Denton, Texas
I just put them on all nice and shiny. Kind of like putting a nice necklace on a lady to doll her up. :wink:
McVeyMac
State College, PA
RE: Re: Put on the Spin On Filters Today!
One could argue that it is a little like lipstick on a pig.
I guess I would paint them.
dabtl
Denton, Texas
They came with the gaskets to adapt the fittings. The filter is better than the older ones and the flow rate is unchanged as I under stand it.
Pressure seems to come up quicker due to the filters holding the oil rather than it draining into the crankcase when stopped.
dabtl
Denton, Texas
The old filters simply drain back after the engine stops. These hold oil after the engine stops. Anti-drain back, I suppose you could dall it. At any rate the filters do not have to refill every time the motor is started to have pressure build up.
Good idea.
alphadeltaromeo
Alto, GA
My spin-ons from jatonka will be installed this weekend. I just purchased the NAPA filters and will post pics of mine as well. The quality of the work is really excellent.
jatonka
87
Ephratah, New York
And another filter available is Baldwin BT-124. It filters at advertised 12 Micron rating. The company tells it's dealers that it is a 10 Micron rated filter. Anti drainback is the correct term, dabtl. And I'll work on the secondary and final adaptors. John Tennis
