jd 9760
- 0
- 0
- Van Wert, Ohio
M923A1: NH250 855 cummins.
Do these engines have glow plugs or a block heater? I'm assuming no since I can't seem to find either.
Has anyone added a block heater to this engine platform before and how did it work for you. I have an 855 in a farm tractor with a block heater which works well so I don't see why the same wouldn't aplly here. What can you tell me about installing one of these or is there one and I'm missing it.
Also can some one explain the electrical system to me. I understand 24volt starter but what else is 24 volt on the truck and what does the 12volt line coming off the battery run. If I add lights or anything electrical to the trcuk does it need to be 12v or 24v Thanks I'm new at this and trying to learn all I can
