question on injections pumps.
84cucv1ton
New Jersey
i found brand new db2 pumps for these trucks. i know a rebuilt one with the newer/updated parts is 250. his price is 180 each. i looked at a bunch of them. i could not find a date.
price seems fair. just want to make sure there not from the 80s or it dosent really matter??
thanks
84cucv1ton
New Jersey
high output for the Military spec???? never knew there was a difference. waiting for him to call back. not sure how many he has im getting a bunch for my family and some friend. if they are the newer ones i will be going for them
watkinssr
Fort Worth, Texa
Did I ever tell you that you're like a brother to me?
1,808
Get part numbers to confirm. DB2829-4267 and DB2829-4386 are for 84-85 CUCV. DB2829-4520 and DB2829-4521 are for 86-87 CUCV. All have hardened parts. I also have a very interesting PDF dealing with issues observed running aviation fuel through them.
1,808
Not much. Most of the DB2 pumps are real similar. Mixing up pumps is more of a problem on the DS-4 pumps from the 94 and up 6.5 GM pickups. Just about any DB2 will work unless its a 28V unit from a HMMWV and even it can be made to work if you swap solenoids.
acmunro
Reynoldsville,PA
Pdf
Could I get a copy of that PDF ?
watkinssr
Fort Worth, Texa
Sounds like a good one for the faq thread. One of my friends in the Navy said they fed them aviation fuel all the time, and were always getting yelled at for it.
84cucv1ton
New Jersey
i think a 93 pump would be a db4? they guy i was talking with a bout rebulding my pump said there really is no reason to go for one. i do have banks and 6.5 turbo kits. he said the db2 is fine. no real gain from a db4. seem to caot a good bit more too
