SasquatchSanta
- 18
- 0
- Northern Minnesota
I want to share this recent problem with anyone that has installed, or plans to install an electric cooling fan on their truck.
As most know, I installed and have made several "electric fan" posts on SS in the past. It works great in the winter. Without the constantly running water pump fan, the electric fan causes the engine to run in the 180 degree range.
With the new, hotter running LDS engine I decided the electric fan was too marginal for summer driving so I re-installed the water pump fan. I left the electric fan in place to act as an auxillary. When winter arrives I'll once again remove the water pump fan and fall back on the electric unit.
All went well until the other day when I noticed the tell-tale light that I installed on the dash to indicate when the fan is running was on. How could this be? The mechanical water temp gauge was only registering 170 and the electric fan isn't suppose to come on until 190. I checked the oil temp gauge. It indicated 180 so the water temp of 170 was logical. As soon as I would stop the check to see if the fan was running the light would go out.
This turned into being a real head scratcher. We did extensive checking and testing. I removed the fuse from the fan and the stupid light still came on. We then learned that the light came on when the engine was reved up. Soldier Number One, being a lot smarter than I am finally realized it was the whirling electric fan motor serving as a generator and feeding power into the tell-tale light. When the motor was reved up the water pump fan would pull air through the radiator and spin the electric fan causing a windmill effect.
Thinking it might be the alternator somehow feeding back current into the ground, we were about ready to pull the alternator. Simple things like this can give you fits.
