Well, I now know for sure what the problem is. I moved the truck and the rear axles straightened right back up. Yes, there is room for the axles to move back and forth some during turns. Now the bad part. As suggested I jacked the weight of the truck off of the springs and sure enough the spring seat bushings/bearings are shot. The passenger side is loose and probably needs bushings/bearings but maybe it could just be tightened. (my 3" axle nut socket is on order)
Unfortunately the driver's side is really bad! There is a huge amount of movement and to make matters worse, the spindle threads must be stripped where the inner nut is. The lock ring will spin and I could turn the inner nut by hand. I started tightening it but it just kept turning.
The outer nut is very tight. I could turn it with a hammer and chisel but for having no bearing tension on it I should be able to turn it by hand.
Thank you to everyone for throwing out ideas and leading me to the real problem. Had I not made the tight turn before parking the truck and noticed the axle misalignment I would not have posted the question and not known I had a major problem. Like they say "ignorance is bliss".
I've only had the truck 5 days and had not gotten to drive it since bringing it home. Now it is out of commission. I pretty much maxed out my budget buying the truck so now the big question. How hard is it to find the whole spindle assembly and how expensive are they? I am hoping that since this is a part no longer used when a deuce is bobbed that maybe there are some out there that are not too expensive.
I'm trying not to be too discouraged. I knew these were old trucks and things like this can happen but I guess I wasn't prepared for a show stopper the first week. Hopefully others will learn from my experience and add this very simple check to their list of things to look for.
