gimpyrobb
dumpsterlandingfromorbit!
- 27,785
- 749
- 113
- Cincy Ohio
So since my trip to N.C. I have had oil dripping from the hole at the bottom of the bell housing. The clutch started slipping on the way home from Findlay. I thought it was motor oil as it appeared the motor oil level was getting lower(need to check it tomorrow). I pulled the trans today and inspected everything. It really smells like gear oil with the trans off. When I pulled the flywheel, it looks in pretty good condition. Since I have never trouble shot a rear main seal before, wouldn't there be some tell tale spots on/near the seal? I think it looks pretty good. Is this something that you will not be able to tell by looking at it(yes I read all the posts I could on rear mains)? I have talked it over with some members and have decided to look over the vent in the trans and some of the bolts that thread from the bell to the trans housing as some pass right through and gear oil "could" seep in those spots. I don't plan to put it together till Thursday or Friday, so all in put is welcome. I have not yet looked at the tag on the motor to see if it has been rebuilt recently and I will get picks of the "coating" that has gathered on the flywheel and pressure plate. Here are some pics that I got with darkness falling.
