niferous
- 6
- 18
- Houston, TX
The title says it all! I got this off a member here who had one on a truck he was parting out. I "think" it's factory but I'm not sure. It just bolts to the side of the body and has backing plates to spread the weight out over the sheet metal instead of just relying on bolts to hold the weight. I am having just a little bit of trouble with the hole that the pin on the tailgate passes through to hold the carrier on the tailgate. It wants to stick on the top and I have to lift up the carrier a little bit to get it on there. Holds solid though and swings out well. I checked and it doesn't sag at all when it's fully extended.
The spot where my plate is the place a jerry can is supposed to go but it's set up for the old metal cans. I'm going to get a base for one of the newer plastic cans. Then I'll move the plate to probably underneath the jerry can holder.
Pics attached and I hope you like.
