wb1895
- 17
- 18
- Lexington NC
I just had to replace the main shaft and the syncro hub for second and third gear in my deuce. I spun the keys holding the hub on......Anyways....
I got a new gasket set and rear seal for the main shaft and I have found a problem. The old rear seal is both a rubber and felt seal, but the new seal I got is half the thickness of the old seal and has only the rubber section of the seal.
Did I get the wrong seal, is the old one obsolete, can I use the new seal in place of the old one???
Thanks for the advice.
Walter
Walter
