driving a few days ago I had a motorcyclist pull up along side me and tell me that my rear wheel looks like it might have some loose lugs because he saw irregular spin from behind.
I pulled over and checked. lugs were tight.
When I got back to the garage and grabbed the rear left corner of the truck and pushed/pulled it side to side, I noticed a sound coming from the rear left wheel like what it would sound like if the lugs were a bit loose.
when I grabbed the top of the tire and pushed/pulled it toward/away from the truck I heard the same and felt the play.
However, when I removed the wheel I cannot seem to replicate the effect.
My first thought after checking radius rod and arm bushings was the spindle nut might be loose.
but when I grab the wheel mating surface and try to shake it or move it(even with a 2x4 for extra leverage) nothing seems to move. there is however a slight sound of what I could describe as "a short squish of grease under high pressure" . I'm thinking maybe ball joints but with my hand on them I do not feel the play.
the sound happens when I am prying up anywhere under the hub.
any easy way to figure out if its the ball joints or spindle nut before taking apart?
