Well, I finally got my deuce...I'll post some pics later.
when I brought her home I found both rear driver's side inner seals are leaking and the rear axle drivers side brakes began to smoke and the pedal grabbed at the top. I've decided to tear down both axles, both sides to go completely through them to determine my shopping list.
Check list:
bearings and races.
inner seals.
outer seals.
brake shoes
emergency brake shoes
wheel cylinders.
small cork keyway gaskets
I don't know what to look for regarding wheel cylinders. Can anyone offer some advice for how to properly inspect and determine the condition of wheel cylinders? Also, I don't know if NAPA carries any of the seals, bearings, races, brake shoes etc. Any info would be appreciated. I'll post pics as I go through the job.
Check list:
bearings and races.
inner seals.
outer seals.
brake shoes
wheel cylinders.
