Relay to turn on brake and turn signals with ignition on?
dmetalmiki
2,030
London England
The hazards in my lmtv are activated by a toggle switch in the panel, which I'm assuming gets power all the time. Maybe I'm wrong, but I don't think changing the power feed to the switch would affect that.
@dmetalmiki For me, my issue is not with forgetting and leaving the lights on. It's forgetting and taking off leaving them OFF. My civilian rides do not require me to manually enable the stop and turn lights every time. For me that is much more of a hazard than needing to leave it switched on to use the hazards (if that were even required).
I'd much rather they come on by default than remain off by default. I can survive the humiliation of forgetting and looking like a dummy, even a ticket for it would not be the end of the world. But man, would I be sad if someone rear-ended my 18k pound truck and got hurt or killed because I forgot to operate the stupid levers. Fixing the all-lights off by default is high on my list.
Good reply...(I just like "Exercising" my 'grey matter' as well as my joints!..)
Most ALL our ' Gang' (When) Traveling in convoy Have ALL the Lights ON.. for just that reason. (Military Vehicles are 'Camo'de for a reason.).
In fact the M62 Wrecker and ALL my Russian stuff travel with the fitted Beacons in action.
Again. GREAT POINT. BE SAFE> .
AS......the BEST way to 'get out of trouble'.......IS to NOT get into 'it' in the first place.:driver:
