ramdough
- 1,729
- 113
- Austin, Texas
I dont think it goes all the way under by the gas pedal. I think it turns toward the rear just before that, under the park and trailer air controls and comes out a hole in the side of the box below the park control. Then it goes around that front corner and right up to the side of the CTIS controller.
U is the speedometer input from the transmission, S is the overspeed signal to the dash light.
What does the CTIS controller side of the connector look like?
can you please Post a picture of where it comes out? My evaporator hopefully has the same hole.I dont think it goes all the way under by the gas pedal. I think it turns toward the rear just before that, under the park and trailer air controls and comes out a hole in the side of the box below the park control. Then it goes around that front corner and right up to the side of the CTIS controller.
FWIW. My old heater unit had a hole in the side right where my right knee is when driving (maybe lower). The wire came out the side panel near the lower rear corner of the unit, and ran around the corner to plug into the CTIS control.can you please Post a picture of where it comes out? My evaporator hopefully has the same hole.
My evaporator does not have that one. Have to think about what I want to do here.
Well send me your Evap and I will send you my heater assembly as I don’t need that hole anymoreMy evaporator does not have that one. Have to think about what I want to do here.
It's the unit that came with the truck from what I know.thanks for the info….. here it is. This CTIS controller may not be original…. @fuzzytoaster ?
View attachment 885046View attachment 885047
