tms308
- 0
- 1
- northern MI
I have 50's Gas motor Reo that was bought from the state surplus auction. (drove it home) It has sat for a long time and now I'm looking to get it to running status. In the past I have pushed/pulled/drug it around the property. Since trying to move it to the shop, I found that the gear shifter will not select or go into any gear at all. I believe I have aced up the sprag gear, since Im sure it was pushed and/or pulled while it was in neutral w/o the clutch held down. The clutch moves freely and seems to have good travel, all levers are moving. I have elevated the front axle and can only get the passenger side wheel to rotate forward and no joy on the transmission shifter going into gear. I searched the threads on here and cannot find a resolution. So my question to the experts; what do I need to do to be able to shift/select the gears and how do I "reset" or restore the sprag gear?? which TM will help me go about fixing my situation? thank you in advance and my apologies if this has been covered before (I couldn't find it)
