I think that I need to change the rear main seal on a REO OA331 engine in a '61 REO M35. I can’t find a TM that references the OA331, and I know some of you have had experience with these engines. Are the seals even still available? Is it a one piece, two piece, rope seal, lip seal?
I don't even know for sure that it is the rear main leaking. There is no oil leaking from inside the bell housing, and with other engines that I have had with bad rear main seals, the fly wheel slings oil while running. The oil appears to be running down the front of the bell housing, but not coming out of the hole at the bottom. I know this because I attached a hose to the bell housing and verified that no oil came out while oil did run down the front of the bell housing. What is the likelihood of it just being a bad oil pan gasket vs. a bad rear main seal?
Thanks for any info.
