dmetalmiki
- 2,031
- 113
- London England
Ok, so I clanged the Hydraulic head, and it leaked fuel into the sump.
I changed the seals (3) times!..Then found out the supplier conned us with miky mouse rubber seals and charged us for vitron seals.
I finally had the right seals in place..Did it start? NO!
It drove to where it was.
So, Why no start?
The small wheel driving the quill off the large wheel in the Hydraulic Head Had snapped off.
WTF?.. So today we took out the injector pump, and removed the offending broken shaft and gear.
We have re-installed the injection pump, timed up as far as the advance driving cog on the frond of the pump.
Tomorrow we are to try and re-install the driving cog...All the fuel lines and oil supply pipes are fitted,
Mystery as to why that gear in the hydraulic head snapped off.
The dreaded button?..No
The plate securing the driving gear in position?
A possibility.
Typical over engineered German (MAN) technology! Remember the WW11 Half tracks? 20,000 grease nipples and bearings which failed in the field.
M series multi fuel engine pumps, FLIMSY INSECURE Button, Clip, Retaining Plate..all miky mouse things that could and do go wrong on a regular basis.
Anyway tomorrow as said we will fit the pump driving gear and set the advance timing and try starting it.
Just so useful I have pumps cogs hydraulic heads and a load of other parts to hand.
So, Why no start?
A possibility.
