GoHot229
- 16
- 18
- Cason Old Field NC. 704-851-9953
Ok Guys, I have an axle leak. Actually its the outer gasket where the axel itself fits into the HUB housing right there at the tire/wheel, which is secured w/bolts, in other words, un-do the bolts and remove and the whole axle will slide out horozontally ie. pull straight out. My question is: if you pull the axle out, will the splined end drop inside....... down to the housing? and when you go to put it back in be tough to slide back into the splines? without putting a drift in one of the bolt holes and prying down to lift the axle (splined end) up to hit the female splined end? I guess what I'm thinking is when you pull the axle out of the diferential splines, when it gets to the end of the splines, will it drop a couple inches? and will you then have to use a drift punch to fit in an axle bolt hole and pry to raise the male 'axle' splined side to meet the 'female' axle splined side in order to push the axle in fully to reinstall the bolts. Am I correct? The alternative is to use two gaskets and cut them across in one spot and install them 180 (cuts) from each other, use ample silicone and cinch it back up, that way you could pull the axle out from the housing just a half inch or so and not have the axle come out of the splines??
