Snarky
- 9
- 0
- Brazosport, TX
The deuce is a dark bastard. Something about that OD seems to suck in the light surrounding it. Legally in Texas, since my deuce is over a certain width I should have marker lights on it.
I've already connected my rear parking lamps to my front parking lamps, so that when my service lights are on, I have front parking lamps. However, I still feel like I'm kind of a target for LEOs and non-attentive drivers merging into me.
I'm trying to find the best way to add marker lamps to the areas where reflectors are currently located. I feel that night driving will become a whole lot safer if other drivers could actually see how big of a vehicle is actually driving next to them.
Personally I would like lamps that were also reflective so that when it's parked it's visible as well, but I would also like them to look military. I'm leaning towards LED lights because I think I want to do a full LED conversion on my truck. Headlights, combo lights, and dash lights. I've even found some 24v LED H3 bulbs to replace my 24v incandescent H4 offroad lamps.
Anyways, I think the biggest challenge aside from choosing the correct lamp assembly for the application, will be actually running the wires and have them look professional. I may weld a metal channel to the bed at each lamp, to run the wires through externally, because the majority of the reflectors are bolted right through the bed into the cargo area, and wires in there run a great risk of being damaged.
I look forward to the 2 pages of comments on why I don't need lamps, how wrong it is to modify a deuce, and other negative comments before I get some suggestions on appropriate lamp types for the application and creative solutions for wire management.
Thank you.
Thank you.
