Update: I’ve cleaned up electrical connections from the batteries to the slave bar (I think that’s what’s it’s called) and all the connections on both of those bars. I applied an electric grease that was recommended on one of the sticky’s.
The WAIT light was staying on amd the truck was difficult to start cold. There was a push button on the dash but the wires were cut. I found that the red/black wire on the GP relay was cut. I reconnected it and the wait light went away. The truck started right up without a any issues. I can only assume someone tried to use the push button to activate the GPS.
I’ve changed the Transmission filter, new gasket, new fluid. I’ve got an issue with shifting into 4x4. I followed the instructions on the visor and while slowly moving forward in D, tried to shift into 4H but it just grinds loudly. I tried to gently force it into gear and it wouldn’t go. After several tries I gave up and tried to put it back into 2H with the same grinding noise and difficulty. Had to really jam in back into 2H but it stats. Not sure what the issue is but I’ll wait on this one.
Next, I’m going to tackle some dash items: headlights, speedo and odometer don’t work, gear shift cable missing, signal cam is broken in steering wheel along with horn and hazard light switch.
