Well, I was so proud of myself because I had demounted and remounted 5 of my duece tires. I was still alive and still had all my fingers and toes. I'm in the process of going from 9 x 20 to 11 x 20. Then on number five I noticed that it was sure easy to just drop the tire with valve stem down on the Budd rim and everything just fell in place. I thought this is just too easy, so I went to the other remaining 9x 20s. Sure enough, I had mounted all five opposite to how the Army had them mounted. They had the valve stem pointed in towards the dish and I had them out. All that work!
So does it matter? Is it really right or wrong or just a standard way vs non-standard? I really don't want to have to break them down again. There is no metal to metal contact between the rim and stem.
On another note: I debated on buying a duckbill hammer, slide hammer, and other things to break the tires down. I decided to used the pieces of angle iron like I had seen discused on here. They worked like a champ! I was very impressed on how well they worked! Not to mention the money I didn't have to spend. To be honest, I have one tire that the angle has failed to seperate but the other 5 were no problem. I may take the jigsaw to the one tire.
Final note: No matter what system you use to break-down tires. It's still hard work! My back was feeling it the next morning!
