camp9
- 9
- 18
- Yooperland, Mi
I've had this happen, it's a bummer when it does, but they charge by the weight and these things happen. I'd call them and explain what happened, you might be surprised that they'll work with you.
I would not bid on GL unless I had a set plan to bid and recover myself-ever!This was my first purchase from GL. Next time I will be more informed. I not trying to blame someone else for my lack of knowledge. Thanks for all the advise.
I do work in the manufacturing business, and when I give a quote I can't tell the customer it will be 30% more because it was more work than I thought. I would be out of business in no time.
How would that work? They based the quote on the weight provided by GL. The shipping company is not liable for that incorrect information. I NEVER use the GL weight estimate unless it makes sense to me. Even then, if I am uncertain, I will estimate a higher weight and I know the price could change after they reweigh the item. OK, so they get the item back to their location and reweigh the item. Now, they determine that the item weighs more than they were told. So, what are they supposed to do? Return the item to the GL location? This is not happening because they'd have to eat the time and fuel to return it and GL would not accept it. I have had items that were reweighed and the shipping cost went up. They never contact you. Shipping companies usually reweigh because a lot of customers will give a lower weight with the hope that their quote is lower...and the shipping companies know this.You think they would call and tell u first and not just charge your card!!!![]()
It wasn't more work than they thought. I was more work than you TOLD them. Unless they went out and inspected/checked the items before they bid, the bid was made on info you provided. There is no difference between you not knowing the correct weight because GL's info was incorrect or if you straight up lied to them in an effort to save a few bucks. The items were heavier than you told them. ( I am in no way suggesting you lied to them, just using that as an example )This was my first purchase from GL. Next time I will be more informed. I not trying to blame someone else for my lack of knowledge. Thanks for all the advise.
I ment 50% of the extra $319.22. I don't want any money back on the $622 that was quoted.Why did you ask for 50% off when you said you were fine with the original price? They only increased the final cost by 32%.
Did they tell you the "quote" was a quote, or an estimate? Did they say the price was firm and correct, no matter what?
Did you weight the shipment on a certified scale, so you have something to prove there was or was not a discrepancy in the weight(if that is what they based the extra charge on)?
I mainly deal with the same broker that I have dealt with previously. That particular broker HAS contacted me with a lower rate once they weighed the item. On the rare occasions that I go with someone I don't know, I usually try to guess a bit high so I am not surprised in the end.BKubu: Ever had a freight broker give you a REFUND after that weigh ticket has it less than the quoted weight? They are all pirates, deal with them as such...
After reading some replies I have decided to sell my 1971 M813 for $1.00
All I need is a card number so I can charge you what I think its worth later.
According to the site rules--NO for sale ads are allowed in the main forum, only in the classifieds, this needs to go or an infraction will be given,After reading some replies I have decided to sell my 1971 M813 for $1.00
