I just had about the most harrowing event of my (surely shortened) life. I had the top of the IP off to adjust the Face cam. I got too comfortable reinstalling the top and I'm guessing I missed setting the lever n the right spot. As soon as I cranked it over all #311 broke loose. I knew what had happened, but I was not prepared for the loud noise, black smoke and overwhelming feeling that the engine would blow me up as I tried to figure out how to stop the engine.
I pulled a battery cable- no luck, the IP return hose, no luck, finally I grabbed the fuel supply line and snatched it away from the spin-on mount. I literally tore the hose apart- the hose clamp kept a piece.
My family came out- I shooed them away as I bent over to choke up the black lung.
I will never, so help me, not have a plan to pull the fuel line in mind next time I mess with the fuel injection pump. Never!
Should I assume the engine is toast?
