SEE (Small Emplacement Excavator) Model FLU419, NSN: 2420-01-160-2754 & HMMH (High Mobility Material Handler) Model FLU10344, NSN: 2320-01-205-8636
Guyfang
25,702
Burgkunstadt, Germany
This is The Thread, for the Tractor, Wheeled, 4X4, DED, SEE (Small Emplacement Excavator) Model FLU419, NSN: 2420-01-160-2754 & Tractor, Wheeled, 4X4, DED, HMMH (High Mobility Material Handler) Model FLU10344, NSN: 2320-01-205-8636, to simplify finding them in the Technical Manual, Misc. TM's Forum. Each Post, below this one, will include a different Publication or TM. As new documents are Posted, this thread will be updated.
I would like to thank members @peakbagger, @Skidpad & @bchauvette for their contributions.
TM’s for the SEE (Small Emplacement Excavator) Model FLU419 & the HMMH (High Mobility Material Handler) Model FLU10344
LO 5-2420-224-12 Dated 1993
TM 5-2420-224-10 Dated 1993 with change #2
TM 5-2420-224-20-1 Dated 1993 with change #2
TM 5-2420-224-20-2 Dated 1993 with change #2
TM 5-2420-224-24P-1 Dated 2001
TM 5-2420-224-24P-2 Dated 2001
TM 5-2420-224-34 Dated 1993 with change #1
TM 5-2420-224-10HR Dated 1993
TM for the Earth Auger Assembly, Model 1650EH-MS, NSN: 2590-01-384-6857
TM 5-2590-512-13&P Dated 1995
Transportability Guidance for the SEE (Small Emplacement Excavator) Model FLU419, NSN: 2420-01-160-2754, the HME (High Mobility Entrencher) NSN: 2420-01-228-8610 & the HMMH (High Mobility Material Handler) Model FLU10344 NSN: 2320-01-205-8636
TM 55-2420-224-14 Dated 1990
SEE (FLU419) Unit Maintenance Handout
FLU419 Handout Dated 1996
Wall Chart, Schematic, for the SEE (FLU419)
Wall Chart for the SEE
Information document: Digging Frozen Ground with a Ripper Bucket
Digging Frozen Ground Dated 1992
Extract from unknown document, Body of FLU419
60 Body
Extract from FM 5-434, Hydraulic Excavators
Hyd Excavators
Partial List of PS Magazine articles dealing with the SEE, HME & HMMH Equipment
ARMY PS Magazine Pertaining to SEE, HME & HMMH
Guyfang
25,702
Guyfang
25,702
Guyfang
25,702
Posted by @peakbagger
Thanks to a Unimog Forum member, General Hood, who located a stash of previously unobtainable wiring diagrams, another forum member had one scanned and made available to all.
Notes, The military diagnostic harness is not shown and to date no one has found any details on the harness.
The diagram appears to cover only the equipment when it left the Mercedes factory, therefore much of the add on equipment associated with the backhoe and rear hydraulics are not shown This would include the remote throttle, rear platform light, remote bucket operator, hydraulic oil cooler and the hydraulic hose reel. These
Guyfang
25,702
60 Body
Posted by @bchauvette
Attached is the civi cab tilt instructions. The TM says nothing about the Cab Tilt Bracket. Also the TM is not clear on unsnapping the hand brake cable can cover. You need to extrapolate the instructions that apply to us.
Note: be sure to mark the steering shaft alignment before unhooking it.
I use a ratchet strap tied to the roll bar and the lifting ring below the back window and an other strap as a safety so I don't overshoot when tilting.
Guyfang
25,702
This file is not a official document, it is collection of extracted maintenance and operation tips from the PS Magazine indexed.
