about a week ago i was on my way home from work and the back end of the truck started hoping around on me, every time i let off the gas and slowed down a bit it went away, i would accelerate and hold speed and after a min or two it would come back. i chalked it up to road surface as Ive had that happen on some roads and parked it.
got the winch back on the truck and went for a ride today. now i get a hard shimmy at 42-45, it goes away and then at 50 it starts bouncing hard (feels like the back) and at 52 the wheel starts to jerk and truck feels like its getting unstable (obviously i backed down at this point).
the winch has been off for about three weeks and prior i had a few vibration problems but nothing like this. anything i encountered was light and went away once the road surface changed or you could accelerate through it. up until now I figured tires but this is outta the blue. quick look over reviled nothing obvious.
just curious if anyone has similar experience, ill check for loose nuts and bolts along the drive line, i thought maybe bearing?? the fronts where solid last i checked but ill check again for play.
