Cantineaux
- 0
- 1
- Belgium
Hello everybody,
Im currently struggling with my SHC35 Hunter heater.
I recently build a new battery for my heater as well as a European usable fuel can as these parts are not buyable in BELGIUM.
When I connect my battery pack and put the ON/OFF lever on, the light turns green and after a couple seconds all the lights jump on for a short moment together with a beep tone. After this nothing happens anymore.
Am I doing something wrong or should the system do something different normally ? I read in the manual that the fans should turn on for a brief moment but this also doesn’t happen.
( when I put the control Nob to 0 the light of “At set point “ turns on and I hear some strange sound coming from the combustion air blower area)
For the battery pack I used 2x 12v battery’s of 7,5Ah connected to a molex connector I used the green and white cable for 1 battery and the black and red cable for the second battery I used the battery charging adapter to find out where to put the + and - for each battery ( I am not sure if these needed to be different for powering the glow plug )
I also have the 2 white wires connected to the connector for if I ever want to put a heat pad ( currently no heat pad attached )
The 2 brown wires go around in a loop connected to a fixed resistor ( to fake a positive 25°C temperature )
Can anybody help me out or tell me if I did something wrong as i don’t know how the machine should operate in normal conditions
Thanx in advance
Verzonden vanaf mijn iPhone met Tapatalk
Thanx in advance
