Shifter knob removal
Jimma
Hartwell, GA
I know this sounds crazy and I must look stupid for not figuring it out but I want to remove my shifter knob in my m35a2 and put something else there that looks cooler. However, I do not want to destroy the original taking it off. Can some one suggest a way to remove it. I have tried unscrewing it by hand, with a strap and a chain type gizmo without success. How can I get it removed without tearing it up? Any help would be appreciated.:)
Westech
CPL
6,104
207
cow farts, Wisconsin
use a rubber strap wrench. There about 10 bucks from Autozone or who ever... Its like a chain pipe wrench but it uses a rubber strap. We use them on things we dont want marks on like SS and Chrome parts.
wreckerman893
Possum Connoisseur
15,618
2,013
Did you check to see if there is a "Jam nut" under the knob holding it in place?
You might apply some heat with a propane torch....(very carefully) to expand the metal bushing that is inside the plastic knob. Get it warm and spray some Liquid Wrench or other lub onto it...the heat will suck it into the threads.
joshgar8
Nashville, Tennessee
I had to use a actual pipe wrench on mine. I did pretty much destroy the knob, but with its age the plastic was almost like powder. Even with the foot long wrench it was still tight as D!cks headband....
littlebob
26
Baton Rouge LA
I second wreckermans post. Don't use to much heat and let it cool after the penetrating oil for a while.
Another Ahab
4,211
Alexandria, VA
Scientifically, is Dick's Hatband:
- MORE tight, or
- LESS tight
Than the fit of a Gnat's A**?
