Shortened M923A2
Dead Reckoning
Forest Grove, Oregon
So I have been wanting to bob the 923, but before I commited to cutting it that much and dropping an axle I decided to just shorten it and see how it looked. I sectioned out 18" from the bed, removed the spare lift and spare, rerouted the exhaust to a 5" straight pipe and moved the bed forward 18". I cut off about 24" of frame and removed the rivets from the rear cross member. Then drilled out the frame and used the rivet holes to bolt up the cross member then I put the shackles and Pintle back on. I also shortened and mounted the mud flaps at a slight angle to clear the tires. So the overall length of the truck is now a full 3' shorter and almost fits in a normal parking spot.
Karl kostman
893
Fargo ND
I really like it, to heck with bobbing keep it this way its got a very pleasant NASTY look to it!
KK
