- 4,810
- 742
- 113
- Liberty Hill, SC
As some of you know, I won the M211 at the Forestry Commission in SC. I'm needing alittle help though.
It is missing the outer tires and rims on both driver side rears, and one tire on the rear pass. side. My question is, I need to flat tow it. Can this be done without putting a tire (or at least a rim) on the outside of the axle? I'm not going far, and not going fast. I've read the manual for the M44 trucks, and it seems that the stud is the inner wheel nut. Is this true for the M211 as well? will the wheel stay on? I would like to tow it with a M35, but can't if I have to take 2 tires off of it and the lugnuts! (the M211 has a good spare)
So will the wheels stay on the M211? or should I look for two more before towing it?
Thanks guys!
Thanks guys!
