noob
- 0
- 0
- West Virginia
Hello folks,
Recently had a u joint drop out on me while i was on the trail. after i popped in a new joint it looks like my slip yoke was damaged in the process and now leaks fluid out of the T-case. At first i thought it was just a weep-hole that you will see on some of these older models but upon closer inspection it is definitely damaged.
So my question is, how do i find the right replacement yoke? I found some for cheap here.
Transmission and Transfer Case Slip Yokes
But i want to make sure i will get the right thing. usually i would junk yard this part but the closest pick-a-part to me is a five hour drive, and i do not really need other parts right now.
Thanks for any light yall can shed on this.
