- 728
- 6
- 18
- New Jersey
I found a small air leak on my deuce which turned out to be the result of dirt and other garbage sitting on top of the bracket that holds the air tanks in place. I guess over time moisture could corrode the exterior of the tank. The hold down bolts were buried in dirt. Not a common place that most people would think about cleaning I would think. Figured I post this so next time your under the truck draining the air tanks run your finger on top of the air tank brackets to check them for debris.
