Autonomy_Lost
- 1,483
- 93
- Pennsylvania
I wonder if you can open them up and modify them?
Exactly what I want to do!I've searched and read through all the spring threads I can find. Lots of good info, but little "follow on" reports of how the trucks ride. Right now I figure our M1123 has had at least 3k pounds of gear removed, so the springs are like bricks. Here is my goal, and I would appreciate anyone who has experience that can help me get to it
So, back to the M1123. This truck has enough wheel travel to put the RR to shame. There is no need for solid rock springs. I would like to drop the rates...a LOT!! Most of the springs I find in the forum are advertising 30% less rate. They all advertise this 30% less rate as though it is a magical fix. Honestly, 30% less rate only accounts for the weight removed in the demil. That takes it from "solid" suspension to "dump truck" rates. I want 1965 Fleetwood spring rates.
In fact, I think the optimum for my use would be springs that would bottom frequently, with the stock ride height, and then stiffen it up with air shocks when needed. I want to glide down the road in my living room couch. The HMMWV weighs very close to what a '65 Cadi weighed, so I know it's possible.
Is this a real risk? Obviously an instantaneous release of immense pressure is potentially deadly, but is it likely? I thought jeep guys ran setups like that, too.Be careful.. That shock installed is the only thing keeping that spring from decapittating someone..
The shock is what keeps the suspension from extending too far. If it does extend too far, there is potential for the spring to shift in it's seat and potentially come out. Our springs don't really have much extension to begin with.Is this a real risk? Obviously an instantaneous release of immense pressure is potentially deadly, but is it likely? I thought jeep guys ran setups like that, too.
While not their intended use, would some 17” limiting straps attached to the stock shock mounting points do the trick? Seems like it would be some margin of safety keeping the spring in place while also keeping the entire assembly from overextending for the rare chance that one reaches full extension.The shock is what keeps the suspension from extending too far. If it does extend too far, there is potential for the spring to shift in it's seat and potentially come out. Our springs don't really have much extension to begin with.
For most jeeps, you're talking limiting straps or just suspension geometry that keeps the spring in place. Most Jeeps are also solid axle, not independent suspension, which changes things up a bit.
I have no idea how likely it is, but it's definitely not impossible.
Some sort of limiting strap should work, but remember they aren't typically designed for shock loading, which is what will happen during rough driving. The shock slows down how fast the spring can extend, and mitigated the shock factor (no pun intended) of the suspension travel coming to a stop.While not their intended use, would some 17” limiting straps attached to the stock shock mounting points do the trick? Seems like it would be some margin of safety keeping the spring in place while also keeping the entire assembly from overextending for the rare chance that one reaches full extension.
Thoughts?
