- 124
- 136
- 43
- Los Angeles/CA
I am trying to rebuild a failed alternator on my M1009, and an having a hard time fining the parts. I bought 2 "rebuild kits" which were allegedly for isolated ground 27SI alternators and specifically listed the M1008/M1009 as compatible applications, but they are missing a lot of critical parts.
Left to right in the attached image are the ground stud, a small stud that was not externally connected (sense terminal?), and the positive stud. My kits came with a replacement postive stud and insulators (which I have installed), but the kit does not have either of the other studs or their insulators. As you can see my hardware is badly corroded and the insulators are partially eroded, and they need to be replaced. Does anyone sell these parts?
I've bought parts from ASP in the past, but this is the only hardware I can find for a 27SI and it does not contain any of the parts I need.
https://www.aspwholesale.com/alternator-parts/delco/hardware-kits/hardware-kit-p12660.html
EDIT:
I ordered 93785A300 and 93785A817 PEEK washers from McMaster Carr. This should get me up and running, assuming they show up tomorrow.
https://www.mcmaster.com/spacer-washers/material~plastic/for-screw-size~no-6/
But if anyone has a source for the correct fiber washers, plastic insulator and rubber cap for the sense terminal, and the B- stud and insulators at a reasonable price I would love to know where to get those parts. I did find the sense terminal hardware here but shipping is $20...
https://iglobalparts.com/new-kit-co...l-6786-49-1511-120-12073-500-12142-120-12014/
EDIT:
