- 545
- 1,309
- 93
- AL
My speedometer quit working, so I tested the cable with an electric drill at two different points. The drive pin/key, part #25, within the adapter was inspected and found to be good. The first test was successful through the cable itself between the adapter and the speedometer. The second test failed when connected to the adapter itself. The adapter part is readily available and one is now on order. But, how common is the adapter as a point of failure?
Thank you in advance,
- HoveringHMMWV
- HoveringHMMWV
