- 215
- 80
- 28
- Rushville, IN
While troubleshooting an issue I've been working on, I noticed that the keyway for the speedometer key looks like the below picture. They keyway is not what I would call a well defined square profile. It almost looks rounded off. Is this how it is supposed to look? This T/C was removed from another vehicle and I bought it to use on a 4L80E swap on my M998. I was having some problems with a pulse generator I used to replace the mechanical cable. I noticed the key was rounded off a bit and a bit twisted. So I'm trying to determine if I did not get it seated far enough into the keyway or if the keyway is bad. I'm not sure what it is supposed to look like but in my feeble mind, I picture it being a more defined sq keyway. Thoughts?
![Keyway.png Keyway.png](https://www.steelsoldiers.com/data/attachments/667/667475-8250499dc278f04ffbe5e5511bcdcab6.jpg)
